Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
09 Accord won’t start after motor swap
Old Feb 8, 2019 | 08:36 PM
kevin916sfs's Avatar
Default 09 Accord won’t start after motor swap
I replaced the 2.4L in my 09 Accord with another 2.4L and now it won’t start. Timing is dead on, has spark fuel and air. Engine code for high voltage in temp sensor and for rocker arm oil pressure switch. It also now has 4 transmission codes. Any thoughts?
Thanks
Old Feb 9, 2019 | 07:38 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: 09 Accord won’t start after motor swap
  • Check ground G101.
  • Check Under-hood Fuse No. 17 (15A).
  • Check connectors to the ECM/PCM.
  • Check the battery terminal connection. Also check the battery negative connection on the chassis.
Old Feb 10, 2019 | 02:32 PM
Thanks, one of the connections on the ECU was loose. I popped it back on and now the car starts, idles for about three seconds and cuts off. Fuse and grounds were both good
Old Feb 10, 2019 | 03:54 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Are there any trouble codes still existing?
Old Aug 3, 2019 | 10:38 AM
Sorry for the long delay, I had to shelve the project for a while. It starts and runs fine for about 10 seconds and cuts off. No codes
Old Aug 13, 2019 | 05:49 PM
Blamm!!'s Avatar
Make sure fuel pump relay is working properly.
Jfrazer22
Jan 13, 2019 04:17 PM
Carlos Cruz
Jul 17, 2017 05:02 AM
carolinacole
Apr 22, 2016 04:29 PM
leper messiah
Aug 30, 2008 12:27 AM
Bewkrazed
11
Dec 10, 2001 05:33 PM
