Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
09 Accord won’t start after motor swap
Old 02-08-2019, 08:36 PM
Default 09 Accord won’t start after motor swap
I replaced the 2.4L in my 09 Accord with another 2.4L and now it won’t start. Timing is dead on, has spark fuel and air. Engine code for high voltage in temp sensor and for rocker arm oil pressure switch. It also now has 4 transmission codes. Any thoughts?
Thanks
kevin916sfs is offline
Old 02-09-2019, 07:38 AM
Global Moderator
tech8's Avatar
Default Re: 09 Accord won’t start after motor swap
  • Check ground G101.
  • Check Under-hood Fuse No. 17 (15A).
  • Check connectors to the ECM/PCM.
  • Check the battery terminal connection. Also check the battery negative connection on the chassis.
tech8 is offline
Old 02-10-2019, 02:32 PM
Thanks, one of the connections on the ECU was loose. I popped it back on and now the car starts, idles for about three seconds and cuts off. Fuse and grounds were both good
Old 02-10-2019, 03:54 PM
Global Moderator
tech8's Avatar
Are there any trouble codes still existing?
tech8 is offline
  • Ask a Question
Question Title:
Description:
