09 Accord won’t start after motor swap
I replaced the 2.4L in my 09 Accord with another 2.4L and now it won’t start. Timing is dead on, has spark fuel and air. Engine code for high voltage in temp sensor and for rocker arm oil pressure switch. It also now has 4 transmission codes. Any thoughts?
Thanks |
Re: 09 Accord won’t start after motor swap
Thanks, one of the connections on the ECU was loose. I popped it back on and now the car starts, idles for about three seconds and cuts off. Fuse and grounds were both good |
Are there any trouble codes still existing?
Sorry for the long delay, I had to shelve the project for a while. It starts and runs fine for about 10 seconds and cuts off. No codes
Make sure fuel pump relay is working properly.
