Drivers side window stuck down
Hello everyone..my window is stuck all the way down..i took off the door panel and tried hotwiring the connector but with no results...i need it in the up position to remove the regulator..it wont budge manually..any idea how to rectify this problem..thanks
Remove the regulator mounting bolts from the door frame, then lift the regulator/glass up till the bolts that attach the regulator to the glass are aligned with the access holes in the door.
RchCrr
Jun 25, 2012 07:38 AM
BULL3TPR00F
Aug 15, 2008 08:28 PM
DOHC_VTEC69
Feb 3, 2005 11:39 AM
855m0n0
10
Jun 3, 2002 03:27 PM
