1994 electric window off track HELP??
Re: 1994 electric window off track HELP??
Position the glass height to give you access through the hole to the 10-mm bolt securing the window glass to the regulator.
While holding the glass to prevent it from falling down into the door, remove both 10-mm bolts securing the window glass to the regulator.
Lift the glass out of the top outside of the door.
Inspect the rubber side channels for damage. Inspect the regulator for damage.
If the side channels and regulator are fine, spray some silicone lubricant into the rubber side channels to prevent the glass from binding there.
Carefully slide the glass back down into the door with both glass edges inserted into the rubber side channels. Lower the glass in this position until the bolt holes in the glass align with the regulator holes. Install both bolts loosely and then slide the bolts into their locked position on the regulator. Tighten the bolts.
Before installing the door panel, plug the window switch back in and then test whether the glass moves up and down freely.
crxaddikt
14
06-21-2011 11:32 AM
DOHC_VTEC69
02-03-2005 11:39 AM
XEF-9X
02-19-2003 05:20 AM
