no spark no fuel no start f22b2 94 accord
Old Jan 31, 2019 | 06:09 PM
Mr Fix's Avatar
Default no spark no fuel no start f22b2 94 accord
Car was running and randomly died and had not started since.
I have no spark no fuel no injection pulse.
At the main relay I do not have power going to the fuel pump black/ yellow wire but the relay clicks and I have power as shown in the picture. The blue and red wire which is labeled for st switch has no power and when I tried to jump power to it, it melted my jump wires so I am getting ground there on terminal 4.
When I jump 12v to the black and yellow wire the fuel pump comes on and I get fuel but still no spark.
The ignition coil is good based on resistance readings and I put on a brand new dizzy before I knew I had no fuel. So with new dizzy still no spark and even with fuel pump jumped at relay no spark.
What else do I need to check, what's next? Ignition switch? How do I test that.
I have no trouble codes or cel, the cel stays solid with the blue connector jumped, so there are no codes to read.
There is no alarm and it's not a coded key.
See picture, red circles mean 12v present with key on, and black circles are ground.
Mr Fix
10
Feb 1, 2019 04:37 PM
01integra_gsr
Dec 10, 2011 11:08 AM
rymander
May 28, 2011 03:12 PM
DOHC_ZC
Feb 16, 2010 06:25 AM
93allmotorcoupe
26
Aug 25, 2007 02:58 PM
