Chubludc2 needs to know - What to change and what has to go-B18C1 Turbo Project
Hello, I have a 2001 Acura integra GS-R, I've had the car for some time now and decided I definitely want to boost it, this is my first ever build so I'm a lil lost about some of the water hoses that are orginally on the motor for it being stock, I'll post some pictures so you can see what I'm talking about, please forgive me if my info is terrible but I'll be willing to answer anything or post more pictures please just let me know and thank you.
There are many forms of turbo charging a car, some people do it the cheapest way possible but that seems to always require maintenance and failure and others will spend the extra money to do things the correct way with quality parts and have better/longer lasting results...... What type person are you? This will help people recommend what you need to get going with your project
I have a list of parts, I'm pretty well invested, and I'm still purchasing parts lol the list will be longer then this soon enough
-skunk2 ultra street intake manifold (stage 1)
-skunk2 70mm alpha series throttle body
-57mm Borg Warner t4 turbo
-speedfactory top mount turbo manifold
-1000cc ID injectors
-chipped p28 on chrome
-skunk2 composite fuel rail
-aeromotive fuel regulator
-4bar map sensor
-g-plus oil cooler kit
-intercooler (with pipping)
-grams oil filled fuel gauge
-AEM 320lph fuel pump
-AEM high flow fuel filter
-ATI super damper
-skunk2 half core radiator
-4bar map sensor
-ATI super damper
Yeah it's taken me a bit to get them but slowly but surely lol I also taken the liberty to upgrade my fuel to a -6an fuel line.
Yes 500hp fingers crossed, I also was talking to a local mechanic, and referred this shop to me. https://cylindersupportsystem.com
He also mentioned buying double double valve springs and titanium retainers, and CP pistons, acl bearings, piston rods ARP main studs, and basicly ARP everything, so I'm in the process of tearing down the motor at the moment. So that's basically why I'm asking the questions of what do I do with some of these oil and water lines and so on and so forth, and also getting a hondata-s300-v3, and not entirely sure of a clutch and flywheel. The mechanic also mentioned cams and cam gears, so any further information is greatly appreciated.
im hoping to have my block back from CSS within the week, they do amazing work and the block should have no problems holding the power you want. I’m in the process of doing probably everything your asking about, have you went through my topic? ( making my return to the fold ) I’ve been asking question and getting answers for 4 months straight, my topic might help you get started
Your list looks like a good start, as far as cams go if I’m not mistaken some GSR cams are a very good choice. And I don’t have the specs on that turbo, but you may be able to gain a little power from a set of ITR cams or Skunk2 Tuner 1. I’ve read aloft of guys have good luck with them in that power range. Good luck woth the build, it looks like your on the right track.
Ok so going off what your saying the skunk2 tuner 1 work with stock valves? Obviously still upgrade the springs and such, but aside from the valves they work well? If that's so that's a big relief man lol cause holy **** getting the head rebuilt for the valves all that stuff is great but its breaking my budget haha but I'll look into those from what I seen they're at about 600$ and the gears are 240$ sooo ohhhh not too bad lol
but I do believe the s2t1 camshafts claim you be able to be put into a stock head. Although upgraded springs and retainers are always good, especially if you plan on visiting redline often.
if I were you, roll your factory head. Many guys have. Maybe upgrade your springs, retainers, and lmas if you have the old style. And just use your GSR cams. Many guys do. I think you’d still be very pleased with the results. I think guys will use gsr cams until 500 HP with no issues. You can spend that money elsewhere and get better results.
That’s what I would try, use that cam money and pick out a Hondata S300 or Neptune demon. Make sure you get ahold of or research your tuner to see what platform they use. Not everyone uses both systems. But both systems perform very well.
^^^^ same as above wouldn’t do a top mount for 500 and street duty. Can’t wait to see how the s257 Borg does for you.
Topmount is good for higher rpm use. They do well, just not that great for street use; Laggy spool response. Topmount has the greater potential for power production since it is a true equal length runner, but, also the bottom of the spool response list. Go mini or full ram.
Chubludc2
Nov 1, 2018 09:03 AM
iBrandon
Oct 17, 2005 08:00 PM
