E85 on larger injectors
Old Jan 24, 2019 | 05:39 PM
USA's Avatar
USA
Default E85 on larger injectors
So if I installed larger injectors that matched how much more you would need to flow for e85 and put in a larger fuel pump, would this work on a stock ecu?
Old Jan 24, 2019 | 05:48 PM
TheShodan's Avatar
Moderator
Default Re: E85 on larger injectors
No. Simply. No. The stock ECU will not handle neither the largest objective, nor the E85 fuel
Old Jan 24, 2019 | 06:04 PM
K7-1Ktrevor's Avatar
Loved
Community Favorite
It might run but why even convert to e85 just to run a stock ecu? The whole point of e85 is a higher knock threshold and cooler combustion temps for higher compression. If your building a motor then just tune it and get the most out of it.
Old Jan 25, 2019 | 08:37 AM
USA's Avatar
USA
well i was just thinking of a way to butch an e85 setup so would already be running on E when I get a hondata but it doesn't seem that feasable
Old Jan 25, 2019 | 09:06 AM
2x0's Avatar
2x0
10 Year Member
Cart before the horse, my friend.
Violentpanda
Sep 11, 2018 02:57 PM
diatibe24
Mar 20, 2015 11:48 AM
99civichx
Jan 21, 2011 05:55 PM
em1_sir
12
Oct 18, 2007 08:01 PM
teg92
Jun 2, 2003 11:35 AM
