Wireing Diagram help
I got a chipped P28 hooked up to a B17A1 in a 1991 CRX. Now what i need help is trying to get my speedometer working. I have the stock SOHC cluster and also got a JDM ITR Cluster. Unfortunatly the SOHC cluster reads the speed by the cable and the ITR one reads it elecronically. I would like to get the electronic one going with the ITR one but dont have the Diagrams. If anyone could help me with this that would be awesome. Thanks.
Hey thanks for your reply, i did some searching and found nothing. What i need is the diagram so i can hook up the right wires to the cluster, i have no idea what wires go where. If you cna help me that would be sweet. Thanks
I believe you can take out your tranny VSS and put in your gear for the stock cable drive. ou should be able to retain the stock cluster. Many B16's do it this way because the SiR (stock to the B16) cluster uses the tranny VSS and not cable.
Electronic VSS has 3 wires...black for ground, yellow for switched power and brown or green goes to the VSS line of your ECU...(B16)..dont forget to reset your ecu after doing the connections.
