connecting rod bearing confusing
Old Jan 17, 2019 | 04:38 PM
Brembomaster's Avatar
Default connecting rod bearing confusing
I bought a set of rod bearing for b18c at parts shop, the sales ask me is it Type-R motor or not, because the b18c1 rod bearing is wider than the B18c5.
In my case. I bought a set b18c1 rod bearing but really not suitable for the rod. than i tell to the sales and he said i should use the type-r bearing.
But i am actually know the crankshaft is not the R version and P72 Stamped on the connecting,i know there are upper and lower bearing id code stamped on rod for the typr-r , and mine just one id code on the rod.
i am confusing that why i issued this problem? do i need to match different size for the upper and lower bearing?
Old Jan 17, 2019 | 09:13 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: connecting rod bearing confusing
GSR (B18C1) and ITR (B18C5) or their JDM equivalent all use the SAME rod bearings. The sales person is mistaken... the B16A and LS/CRV rod bearings are wider. What brand of bearings are you buying ???
Old Jan 17, 2019 | 09:26 PM
thanks you for reply!
Just buying the honda oem and all in brown. I took the wrong back to the parts shop to exchange,but they only have 3 pairs in brown, Sad..I dun know is it work to try 3 pair in brown and 1 pair in green.I dun know is it work
Old Jan 18, 2019 | 10:53 PM
JRCivic1's Avatar
10 Year Member
Community Builder
It depends on the markings found on the block, crank and rods. Three brown and a green pair may work.
Old Jan 18, 2019 | 11:01 PM
Thanks you, I am looking for pair of brown from other shop, i think depends on the marking should be the best choice.
igorka_91
13
Jul 5, 2009 12:29 PM
dj-t
Jul 2, 2009 08:48 AM
mattb16a1civic
Oct 30, 2003 02:56 PM
Plan B
Oct 18, 2002 06:42 AM
