1991 Honda Civic wont start.
Old Jan 15, 2019 | 09:03 AM
BigMac28's Avatar
Default 1991 Honda Civic wont start.
1991 Honda Civic 4 door Sedan. 1.5L and 5 speed manual transmission. I went to start it up three days ago it fired up idled for maybe 5 minutes then died. Would not start after that. Checked for fuel. Got it. Checked for spark did not have it. Troubleshot back to distributor and replaced. I now have spark. Still will not run. Timing is good. Compression is around 120 PSI plus or minus 3PSI on all 4 cylinders. It will crank but no start. I had an extra known good main relay laying around changed it. No change still will not start. I took off all stock air intake. Nothing. Anyone have any suggestions.
Old Jan 15, 2019 | 10:13 AM
stampern22's Avatar
Default Re: 1991 Honda Civic wont start.
Check grounds (mainly thermostat), are you getting any check engine codes? Might try some starting fluid, if it starts with starting fluid and dies then you've got a fuel problem. If it doesn't start with starting fluid you might still have a spark/timing problem. Couldn't hurt to double check your the timing on your timing belt - they've been known to jump a tooth or two before.
Old Jan 15, 2019 | 10:16 AM
dilbeckskate's Avatar
main relay
Old Jan 15, 2019 | 10:17 AM
BigMac28's Avatar
No it will not start with starting fluid. I have double and triple checked timing. I have checked wiring diagram for spark plugs to distributor. Idk. I feel like i am missing something simple. I will check for ground. Also it is not throwing a check engine light or any codes
Old Jan 15, 2019 | 10:18 AM
BigMac28's Avatar
I have already replaced main relay. No change.
Old Jan 15, 2019 | 10:37 AM
stampern22's Avatar
Have you verified that you have spark on all 4 spark plug wires? And is the spark any particular color? Yellow/Orange or Blue? Also, have you verified that the rotor is turning when you crank the engine - I've seen cams snap before. Did you have to put a new cap and rotor on or did it come with them? I believe the obd0 distributors are able to get the rotor on backwards (180 degrees off, but usually that will cause a backfire issue).
Old Jan 15, 2019 | 11:25 AM
BigMac28's Avatar
Yes all plugs were verified. Idk on color will get back to you tonight. I did not replace caps or cables. Yes i verified rotor spinning. I bought the MAS Ignition Distributor TD-01U. Color looks white blue when cranking
Old Jan 15, 2019 | 12:26 PM
BigMac28's Avatar
Timing photos. The lower pulley is lined up with the middle mark could not get good photo.
Lower pulley. Not camshaft pulley. Pointer lines up to middle line.
Camshaft pulley
Old Jan 15, 2019 | 12:41 PM
BigMac28's Avatar
Better photo
Better camshaft pulley photo
Another
Old Jan 15, 2019 | 12:47 PM
stampern22's Avatar
For timing you should be using the single mark to the left of those 3. With that lined up the lines on cam pulley should line up flat where the head and valve cover meet up.
Old Jan 15, 2019 | 01:09 PM
BigMac28's Avatar
Okay thank you. So my timing is way off. Thank you will update with fix or no fix
Old Jan 15, 2019 | 01:25 PM
stampern22's Avatar
It looks like both will be going the same direction, so it could still be on, but the horizontal lines on the cam gear should be perfect straight with the top of the head and the lower as I explained before. I would line up the bottom one and see how the cam gear looks.
Old Jan 15, 2019 | 01:31 PM
BigMac28's Avatar
So it should be a single mark on my lower pulley. None of the 3 marks? Should be a single line by itself?
Old Jan 15, 2019 | 01:35 PM
stampern22's Avatar
Correct, that's belt timing mark, the other 3 are for use with a timing light to set the timing on your distributor.
Old Jan 15, 2019 | 01:49 PM
thermostat ground ?
Old Jan 15, 2019 | 02:13 PM
BigMac28's Avatar
Give me a little bit. It takes time for the ground i have college when i get back tonight i will check the thermostat ground.
Old Jan 15, 2019 | 04:07 PM
BigMac28's Avatar
If i had a thermostat ground i wouldnt be getting fuel or spark and i am getting both.
Old Jan 15, 2019 | 06:17 PM
BigMac28's Avatar
All right i believe timing is set right this time. Here are some photos once again no start. Cranks over tho.
One line ndot the middle three lines on crankshaflt pulley
Lined up on camshaft pulley i think.
Old Jan 15, 2019 | 06:39 PM
stampern22's Avatar
That timing looks good. What color is your spark if you can tell?
Old Jan 15, 2019 | 06:44 PM
BigMac28's Avatar
White maybe kinda blue on all four plugs
Old Jan 15, 2019 | 06:50 PM
BigMac28's Avatar
Thermostat ground to various different grounds is good. Such as intake manifold, negative lead and a shiny spot i made on car
Old Jan 15, 2019 | 07:18 PM
BigMac28's Avatar
Just to be sure does anyone have diagram from spark plug to distributor for 1991 honda civic 1.5L. Just want to check i have looked it up online but want to make sure i am getting it right
Old Jan 16, 2019 | 07:10 AM
scelestus's Avatar
Old Jan 16, 2019 | 07:54 AM
BigMac28's Avatar
Well distributor and spark plugs have been checked anyone got anything else i can try
Old Jan 16, 2019 | 08:09 AM
stampern22's Avatar
Does the engine sound any different? Like it turning over easier, or harder?
