1991 Honda Civic Si Hatchback 1.6 moonroof seal
Old Jan 13, 2019 | 04:21 PM
civicali's Avatar
Default 1991 Honda Civic Si Hatchback 1.6 moonroof seal
1991 Honda Civic Si 1.6L Hatchback
I have a leaky moonroof that I need to fix.
I have a brand new Genuine Honda seal with part#70080-SH3-A01ZB that I purchased years ago.
I noticed that the seal is long and not a perfect fit. I guess I was expecting a perfect fit seal that would install more like a valve cover gasket. The seal has two ends.
Do I have to remove my moon roof to install?
Do I need some type of sealer?
Please advise
Old Jan 16, 2019 | 11:33 AM
efdave's Avatar
Default Re: 1991 Honda Civic Si Hatchback 1.6 moonroof seal
Have you tried to clean out the drain tubes yet to see if that helps
Old Jan 16, 2019 | 11:35 AM
efdave's Avatar
If they are clogged up that could cause water build up in the sunroof pan and when you accelerate or hit the brakes it will dump out all over you😠
Old Jul 6, 2019 | 09:26 AM
civicali's Avatar
Should of done this 15 years ago.
Old Jul 8, 2019 | 04:28 PM
efdave's Avatar
I also found out if the seal around the antenna is bad that will cause water to spill out onto the driver side floor as well...I just disassembled the antenna and traced the old seal onto a rubber gasket material and it fixed it perfectly
Old Oct 12, 2019 | 12:27 PM
civicali's Avatar
Cleaning the drains worked. No more waterfalls.
Old Nov 16, 2019 | 07:51 PM
honda90civicsi's Avatar
Exactly the fix for my 1990 Si, that my independent Honda service place figured out. Who'd thought it would be that simple :-)
hondasipos
Honda Civic (2006 - 2015)
Jan 4, 2017 06:49 PM
dc2low
Feb 15, 2013 06:41 PM
dc2low
Feb 12, 2013 02:35 PM
