Question about honing a cylinder
Old Jan 9, 2019 | 06:28 PM
BigMac28's Avatar
Default Question about honing a cylinder
I have a 1991 Honda Civic Sedan DX 1.L. I need to do a tear down cause i am burning oil. No leaks. I have replaced the PCV valve. I am assuming the piston or piston rings. Anyway i know honing is delicate work so i was thinking using a flex hone 400 grit or 600 grit. Any thoughts? Should i go lower or higher grit?
Old Jan 11, 2019 | 07:24 AM
hondamark35's Avatar
Default Re: Question about honing a cylinder
this probably belongs in "Engine Machining & Assembly"
I've used flex hones on D-series and F-series with good results. they're easy to use and it's really all about visual inspection. if it looks good it should work fine. I'll take a look and see what grit i used and update later today.
for oil consumption from worn or stuck rings (clogged with carbon/sludge) just as important as the hone job is getting the pistons thoroughly cleaned. I have first hand experience with B-12 Chem dip and would recommend. soak them over night and they came out like new the next morning. i'm sure there are other similar products available too.
also confirm your cylinder bore taper and roundness with a dial bore gauge so you know you're working with an in-spec block.
Old Jan 21, 2019 | 05:53 PM
Txdragon's Avatar
I've just recently learned a good deal about the honing process and **thought** it was simple. It isn't. Different rings require different finishes. Anything you do at home has a 50/50 chance of offering successful seating.
Old Jan 22, 2019 | 04:24 AM
is there a source (article, video, book...) you can site where you learned about honing so we can all benefit from the info first hand?
Old Jan 22, 2019 | 05:09 AM
Txdragon's Avatar
That info came from the machine shop. If you buy a set of pistons; Arias, Wiseco, CP, etc, they will give you a sheet in regards to the proper method needed to hone the cylinders for adequate ring seating. I asked about this and was informed that they are quite specific and while you could just go buy a hone tool, this may or may not be sufficient. 50/50 chance of seat or no seat. Lol!
Old Jan 22, 2019 | 05:28 AM
BigMac28's Avatar
Okay thanks. I will buy the rings first from Hasting and get the sheet. Then buy the hone tool. Thanks guys.
Old Jan 23, 2019 | 06:17 AM
CP has their install sheet PDF available on their website. you're right it's very specific! it even specifies not to use hand honing method (I would consider flex-hone or bottle hone a "hand" method). but that's understandable with high performance parts and applications.
I think for the OP who's engine is worth less than a set of those pistons... and most oil consumption correction/quick and dirty rebuilds, meeting the spec in the FSM for bore geometry, finish and hatch angle (achievable with a flex-hone and a reasonably priced bore gauge) and following a tried and true break-in procedure will ensure the rings are seated well enough.
Paegelow
May 22, 2010 08:10 AM
lude98SH
Dec 20, 2007 05:05 AM
ACrite3404
Dec 12, 2004 10:38 PM
filetofit
Sep 24, 2002 04:03 PM
J T*
Feb 22, 2002 03:05 AM
