piston install
Old Dec 12, 2004 | 04:57 PM
ACrite3404's Avatar
Default piston install
i was wondering when im installing my new pistons if i should lube them before i put them into the cylinder?
thanx
Old Dec 12, 2004 | 07:25 PM
IN VTEC's Avatar
Default Re: piston install (ACrite3404)
Yes, but only after you've determined that the new pistons are not going to be too tight (or way too loose) in the bores.
The cylinder walls should also be finish honed to 400 grit (if OEM rings) and plateau honed to provide proper surface finish to allow the new piston rings to properly lap themselves in with the bores.
Old Dec 12, 2004 | 08:30 PM
lke2drvgsr's Avatar
Default Re: piston install (IN VTEC)
the walls should have a 60 degree angle honing job on them to allow proper oiling.. i dont think there's a need to use assembly lube, just oil up the walls good so you dont get a dry startup
Old Dec 12, 2004 | 09:35 PM
dick_213's Avatar
Default Re: piston install (lke2drvgsr)
ya just use normal engine oil on the pistons... that should lubricate the cylinder walls as well.
Old Dec 12, 2004 | 10:38 PM
ACrite3404's Avatar
ok thanx fellas
Ep3tat98
K Series
Feb 3, 2016 10:20 PM
Jeanious
Oct 28, 2007 03:44 PM
mrdan4548
Nov 26, 2004 07:33 AM
yusoslo
Feb 9, 2004 03:13 PM
B20LS-T
May 13, 2003 04:17 PM
