Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Mass air flow sensor after engine swap from 2003 - 2005
Old Jan 5, 2019 | 08:03 PM
John Shotton's Avatar
Default Mass air flow sensor after engine swap from 2003 - 2005
so my 2nd question, I swapped a 2.4l engine from a 2003 and put it a 2005 Accord Got the engine running but I get a P0102 error code low voltage on the mass air flow sensor. So I google it, go check the connector. Ugg the 2003 motor didn’t have a mass air flow sensor or the wiring
So, I dont know what to do. Do I do a wiring swap. Or pull the ecu from the 2003 and have it reprogrammed with the right vin ( no clue on how this is done).
is there a way way to turn off that sensor in the ecu? Any help would be great.
thanks
Old Jan 6, 2019 | 09:39 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: Mass air flow sensor after engine swap from 2003 - 2005
03-04 Non-SULEV only had IAT sensor.
03-04 SULEV had MAF/IAT combo sensor.
05 had MAF/IAT combo sensor.
If you use the air intake system from the 05, the MAF/IAT sensor is on that, which would connect with the 05 wiring.
Old Jan 6, 2019 | 10:12 AM
Kinda what I thought, I have to pull the wiring off the 05 engine, glad I didn’t sell it. Thanks, hopefully it doesn’t take too long to do a wiring swap.
kmarolla
Honda Civic (2001 - 2005)
11
Apr 13, 2016 05:53 PM
solman74
Sep 13, 2003 12:13 AM
shorty91
Jun 27, 2003 11:18 AM
JDM Accord
Aug 26, 2002 01:28 PM
