Please for the love of god help!!
I have a 2000 Honda Civic hx automatic (cvt tranny) I have a surging idle after replacing the idle air control valve, cleaning throttle body, replacing spark plugs and wires.
Last edited by Bruce Gordon; Jan 6, 2019 at 09:07 AM. Reason: Solved the problem!!
cel codes? grab some carb cleaner and spray it around, if you have a vacuum leak you'll notice the rpm's go up from the spray
[QUOTE=muellersfan;51823176]Is CEL code P0505 thrown?
Check whether one or more vacuum hoses on the IM are disconnected.
Did you replace the TB gasket and torque the nuts and bolts to spec?
I put the same throttle body gasket back on and torque it to spec
vacuum hoses on the “Im”?? What’s the IM again?
PROBLEM SOLVEDDDDDD!!
SOLUTION ::
Morning Sex = Good Luck!
i cleaned the old iacv and swapped them back out and so far the idle sounds perfect! I guess I got a bad iacv !
SOLUTION ::
joshua89
Aug 20, 2011 01:47 PM
