SOLVED!! Please for the love of god help!!
I have a 2000 Honda Civic hx automatic (cvt tranny) I have a surging idle after replacing the idle air control valve, cleaning throttle body, replacing spark plugs and wires. |
Re: Please for the love of god help!!
cel codes? grab some carb cleaner and spray it around, if you have a vacuum leak you'll notice the rpm's go up from the spray
Coolant level full? |
Is CEL code P0505 thrown?
Check whether one or more vacuum hoses on the IM are disconnected. Did you replace the TB gasket and torque the nuts and bolts to spec? https://cimg9.ibsrv.net/gimg/honda-t...d16a006ad6.jpg |
So far no cel already replaced idle air control valve i thought about cleaning the old iacv and putting it on and seeing how it will be |
[QUOTE=muellersfan;51823176]Is CEL code P0505 thrown? Check whether one or more vacuum hoses on the IM are disconnected. Did you replace the TB gasket and torque the nuts and bolts to spec? I put the same throttle body gasket back on and torque it to spec vacuum hoses on the “Im”?? What’s the IM again? |
It sounds like it has an oversized cam in it 🤦🏻*♂️ |
It sounds like it has an oversized cam in it? |
I’ll check coolant level I read possible air in it from replacing the valve |
cover iacv hole in throttlebody, what does the idle do?
PROBLEM SOLVEDDDDDD!! SOLUTION :: Morning Sex = Good Luck! i cleaned the old iacv and swapped them back out and so far the idle sounds perfect! I guess I got a bad iacv ! |
Originally Posted by Caoboy
(Post 51823157)
Air trapped in the system can cause the idle to bounce. I believe it’s related to the iacv not registering coolant temp |
Originally Posted by Bruce Gordon
(Post 51823352)
