96 Civic EJ6 (Auto transmission Hesitate changing Gears)
Old Dec 26, 2018 | 01:50 AM
Tie Ee Fei's Avatar
Default 96 Civic EJ6 (Auto transmission Hesitate changing Gears)
Is there anything i shall check ?
it drive and will change gears no problem with normal drive...
But When i whack the throttle (Vtec kick in yooo lol) the gearbox will hesitate changing gears ..
so i have to let goes my throttle for it to upshift ..
The ATF oil seems Pretty fresh and enough..
but u will feel the car (jump) abit when changing gear...
and is this possible cause by a damage engine mount ? <===== i have a broken engine mount . and new one is on the way ..
And pardon my bad english hope you guys know what i am saying
Thankssssssss
Old Dec 26, 2018 | 05:07 AM
muellersfan's Avatar
Default Re: 96 Civic EJ6 (Auto transmission Hesitate changing Gears)
Do multiple ATF drain-refill cycles.
Old Dec 26, 2018 | 05:51 AM
mk378's Avatar
well if you have a broken engine mount the engine is going to jump around.
By design, the engine will rev higher before shifting when the gas pedal is floored. It should still shift before the redline rpm if you keep pressing on the gas. It is not recommended to do this very often because of wear on the transmission.
An automatic Civic is not going to be very fast, or very quiet and smooth.
Old Dec 26, 2018 | 02:01 PM
Tie Ee Fei's Avatar
​​​​​​Will consider to do that.. Any recommand on atf oil?
Old Dec 26, 2018 | 02:06 PM
Tie Ee Fei's Avatar
This is the engine mount that i mention.. It look broken.. When low rpm the cabin are vibrates.. So i am wondering does it effect on the autotramission gearbox
When whooping I hit 85xx rpm for few sec before it changes gears.. Sometimes it changes some times no.(unless i release throttle)
Sonner or later i will Replace the autotramission to manual transmission...
Old Dec 26, 2018 | 06:02 PM
Castrol Import Multi-vehicle ATF
Old Jan 4, 2019 | 01:33 AM
Tie Ee Fei's Avatar
and updated...after changing my engine mount.. Problem still there... duh..
but i found that the problem occurs especially when the gearbox is hot ( Normal operating temperature ) it work perfectly fine when the engine and gearbox is cooler, will try to do multiple ATF drain-refill cycles ... this few week after i am free.
VXvtec
Oct 27, 2012 08:49 AM
SlammedDC2teg
Apr 28, 2012 12:46 PM
AccordInspireSE
Dec 4, 2008 10:37 AM
vortexx
Nov 17, 2006 12:44 PM
Turbo Powa
16
Jun 2, 2002 09:19 AM
