Engine vibrating
Old Dec 2, 2008 | 05:04 PM
AccordInspireSE's Avatar
Default Engine vibrating
Hi all,
I have 91 accord SE, problem is engine vibrating due to the drop from the jacks. the whole front dropped to the driveway, and afer that it caused vibration. I changed new suspensions, rotors, brakes, front engine mount
and it is still vibrating.
the car is vibrating when it is in P gear and it's vibrating alot when i shift to R gear.
Can someone help me solve the problem?
Old Dec 2, 2008 | 05:27 PM
P_Adams's Avatar
The rear trans/engine mount has failed.
When it goes south, the engine grounds against the body frame and all manner of vibrations break out.
Old Dec 2, 2008 | 05:31 PM
what's about when it's just in P gear? it is vibrating little but not bad as when shift to R
Old Dec 2, 2008 | 05:32 PM
i am thinking of TRANNY MOUNT, but not sure
Old Dec 2, 2008 | 05:35 PM
P_Adams's Avatar
It gets worst as the engine shifts it's orientation (tilts)
Inspect the rear mount. You'll see what I'm talking about.
In "Park" it's at rest and assumes a more upright position. When you put it in gear, it tilts
P
Old Dec 2, 2008 | 05:36 PM
P_Adams's Avatar
It's called by either name.
You'll find it in the Honda Parts catalog under engine mounts. (sorry) force of habit
Old Dec 2, 2008 | 05:41 PM
Hi P Adams
i just read this from other site, he said there is a electronic control located in rear mount
is that one of the problem?
Old Dec 2, 2008 | 05:50 PM
P_Adams's Avatar
Actually the rear mount utilizes vacume to assist supporting the engine/trans assembly. It is controlled by a switching solenoid. In most cases, the activation system is pretty much bullet proof; but you mantioned this occured after the car dropped off some jack stands correct?
If you have a vacuum pump (with a gauge) you can determine if the mount still holds vacuum.
This failure is not uncommon on Honda's.
P
Old Dec 3, 2008 | 12:21 PM
yea, after it felt off from the jacks, the whole front slammed on the driveway floor.
One thing i didn't mention was the oil pan got dented, i don't know if that caused the engine shakes (vibration) (not sure)
but I will change all the mounts to see how it is, that is the only way.
Old Dec 3, 2008 | 12:24 PM
oh one morething, when i put to D gear, then the car is normal. drives smooth.
but when i start hit the brake to stop at red light, it starts vibrating and shakes a little
Old Dec 3, 2008 | 12:46 PM
Audz's Avatar
the motor is vibrating.. because its running
there ya go.
all solved
Old Dec 3, 2008 | 05:03 PM
mavvrik's Avatar
P Adams is on the money.
Rear Tranny/Engine mount and your all good
Old Dec 4, 2008 | 10:37 AM
crusto2k3's Avatar
Hey since we are talking about rear mounts, I was inspecting mine today and notices some fluid (brake?)around the base and on the mount...time to replace? I do have some, not bad, shaking in reverse.
Xavier_11
Aug 29, 2018 10:18 AM
VXvtec
Oct 27, 2012 08:49 AM
Marlon88
Nov 22, 2004 03:12 PM
lukejurg
Dec 12, 2002 04:30 AM
