help w/ vafc wiring problem, cel 3
Old Nov 13, 2002 | 07:16 PM
TurboBumblBee's Avatar
Default help w/ vafc wiring problem, cel 3
iight fellas, got a little problem installed my vafc agian into my civic after removing it to relocate it and now im getting a CEL code 3 which is for the MAP sensor.. where did i **** up?? i have checked the wires and everything looks ok.. ive heard of vafc can make the car throw this code but i dont see why or how to fix it.. need some help..
Old Nov 14, 2002 | 08:52 AM
Default Re: help w/ vafc wiring problem, cel 3 (95CivicEX)
ttt
Old Nov 14, 2002 | 10:49 AM
drewspeed's Avatar
more than likely a loose connection. I had the exact same problem. Re-check the pressure sensor wire for a loose connection. What type of connectors did you use?
Old Nov 14, 2002 | 01:09 PM
Default Re: help w/ vafc wiring problem, cel 3 (drewspeed)
got it working.. had to be a loose connection somewher, i ended up soldering and taping everything this time to make sure it was a good connection..
DarkBB4
Dec 12, 2004 11:56 AM
TurboBumblBee
Nov 8, 2003 10:44 AM
.Beaver
28
Nov 19, 2002 04:31 PM
TurboBumblBee
Nov 15, 2002 11:08 AM
VTECHGSR
Dec 12, 2001 08:55 AM
