D15B2 No power, stuttering bad.
Old Dec 16, 2018 | 12:38 PM
scout3221's Avatar
Default D15B2 No power, stuttering bad.
Changed :
Spark plugs, wires
Distrubitor and coil
Fuel pump changed (Not new. Have not messured the pressure)
at first it was sutttering just a bit, but after a while it started to loose power and now i can barely start it.
Old Dec 16, 2018 | 05:49 PM
muellersfan's Avatar
Default Re: D15B2 No power, stuttering bad.
Pull the CEL codes.
Old Dec 17, 2018 | 05:00 AM
scout3221's Avatar
When i jump the connector, it blinks fast 3 times (CEL).
Old Dec 17, 2018 | 09:34 AM
Test the MAP sensor circuit.
Old Dec 18, 2018 | 05:39 AM
scout3221's Avatar
MAP sensors seems to be working fine, i had few of them, tried each one.
cylinder compression is decent.
i pulled injectors out, 3 are working fine and 1 was acting strange, but still working.
Can timing belt strech or something ? (That would explain the back firing, misfires)
Maybe i need to clean the intake manifold ?
Im running out of ideas.
Old Dec 18, 2018 | 05:50 AM
russ.shafer
May 19, 2013 02:29 PM
mortificationrock
Aug 18, 2010 08:22 PM
kreatekustomz
Mar 1, 2010 02:12 PM
em14ever
Jun 27, 2007 04:39 PM
White98LS
May 4, 2003 08:12 PM
