wont crank issue
i try to start my 97 acura integra and all its doing is the main relay is clicking when i try to crank it...... i need some help its not powering up my fuel pump and is dead in the water
Do you have a multi-meter?
Do you know how to bypass a relay?
How about cleaning up battery posts and terminals?
Also don't forget the grounds?
to normalize the electrical system and eliminate possible corrosion?
Cleaned the battery terminals and all the grounds main relay keeps clicking when I try to start it the dash lights dim then become bright again when I stop trying to crank it
5 speed? Automatic?
5speed - Your starter is toasted. Have someone turn the key while you bash it with something. Might get lucky for a few more start-ups, but you need a new starter.
That didn't work? Have that other person push the car and bump start it. Drive to get a starter.
Why are you posting your Integra question in the Civic forum?
It cranked before because the starter was working. Now it isn't. If it isn't cranking it's because the engine isn't turning, not because it isn't getting fuel.
Not getting fuel, the engine will still turn over.
Have your friends push the car and bump start it.
Fine. Keep going about it your way.
Fuel pressure doesn't turn the engine over, the starter does. Forget about fuel for now. If the engine starts cranking, and still won't start, then check fuel and ignition.
No cranky = battery/ignition switch/starter/seized engine.
if you're not hearing the clicks then open up the main relay and look at the soldering for cracks. Also bridge pins 5 and 7 on the relay harness plug and listen out for the fuel pump priming, this needs to be done with ignition on.
brandejo
Sep 22, 2013 03:41 PM
