Tire tearing off front bumper.
Old Dec 15, 2018 | 11:45 AM
Silentz's Avatar
Default Tire tearing off front bumper.
I bought a civic and it has full coil-overs that was max out and the car sits real close to the ground. It rubs against the inside of the wheel well every little bump. I raised it up 2 inches and my 2 front tires rubs against the front bumper and tearing it off when doing a hard turn. I raised it up 3 and 4 inches and still rubs.
Current setting:
LS webs with 195/60/15. Should I change the tire out to 195/50/15 or 195/45/50? Would that prevent the rubbing?
Thanks in advance.
Old Dec 15, 2018 | 01:09 PM
tony_2018's Avatar
Fish Twig
Default Re: Tire tearing off front bumper.
sure, but you'd end up with a tire gap
Old Dec 15, 2018 | 01:45 PM
Silentz's Avatar
what do you recommend? Either I go real low and let it rubs against the wheel well or raise it up and let it rub my front bumper off. Is there a middle ground somewhere I dont know about?
Old Dec 15, 2018 | 05:42 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
195/55R15 is the stock size, so why don't you try that first. At stock height, it will not rub unless there is body/fender damage to the chassis. The more you lower the vehicle from the factory height, the greater the chance that you will have tire contact with the body. Everyone likes the lowered look... but not everybody likes what negatives come along with it.
Old Dec 15, 2018 | 06:23 PM
tony_2018's Avatar
Fish Twig
you can get smaller tires, and then lower your ride some more. But be warn, I don't really care what happens to your car. I'm just giving you suggestions on what you want to do.
Touch
Jul 2, 2006 02:34 PM
miksew
Jun 29, 2005 02:03 AM
BoostedH23a1
Oct 7, 2003 04:53 AM
TorontoR
Aug 9, 2001 08:16 PM
