Late model engine swapping questions
Old Dec 11, 2018 | 09:15 PM
BongoBennie's Avatar
Default Late model engine swapping questions
My target donor car would be a 2010 era Acura MDX with SH-AWD although I would like to keep it a general late model swapping question. In regards to CAN-BUS, If I were to use all the factory sensor, gauge cluster, shifter, etc. can I delete things like the radio and use A/C system from a different car? I also have to make this work with a factory ECU as I need a working OBD2 port for emissions testing. KTuner is available and might be utilised to make the swap easier but the factory performance would be more than adequate.... Any knowledge out there? Thanks in advance.
Old Dec 14, 2018 | 08:26 PM
Freedo_Civegra's Avatar
Default Re: Late model engine swapping questions
What’s this going into?
Old Dec 15, 2018 | 08:26 AM
1G Insight but it really could apply to any car where OBD2 compliance is necessary. Keep in mind 300hp is plenty and I want an automatic.
Old Dec 15, 2018 | 09:53 AM
Why automatic?
Old Dec 15, 2018 | 09:56 AM
Why are you asking? Its because its what I want. Do you have any knowledge on the original questions I have?
Old Dec 15, 2018 | 10:28 AM
Yes, I do. Do you have any knowledge on humility?
“In regards to CAN-BUS, If I were to use all the factory sensor, gauge cluster, shifter, etc. can I delete things like the radio and use A/C system from a different car?”
Yes, the only thing I’m using on my swap is the ECM. It lists codes for having lost communications with the BCM, Instrument cluster, and ABS; but I don’t think these will set a CEL.
“I also have to make this work with a factory ECU as I need a working OBD2 port for emissions testing.”
Ok, you’ll just need a factory ECU and hook it up to your DLC. That’s what I did in my car.
KTuner would be great for switching codes off like “lost communications with _____.”
Old Dec 15, 2018 | 10:38 AM
Yes I have knowledge on humility but I'm asking a question and you're asking me questions that are not helping me so you are not very helpful.
Don't know any details about you or your car, your post history is nothing but one line questions on everyone else's posts....
Im asking for help because I lack the knowledge, you are talkinging to me like I'm dumb.
Tell me how being more humble to you will make you happy?
Old Dec 15, 2018 | 11:13 AM
Did you read the whole reply? I tried answering the questions that seemed most important.
I took you as coming off a little demanding. My questions about your setup were to try to get more insight into your...Insight. Lol
Search: J30A4 EK
That’s my car. Still needs a TON of work!
booboo782
Engine Management and Tuning
Dec 12, 2015 12:14 PM
94_DEL_SOL_VTEC
May 5, 2011 08:05 AM
silva95teg
May 30, 2006 11:53 PM
93civicEX
Dec 26, 2003 01:01 PM
LSVTEC96HB
Mar 29, 2003 03:40 PM
