B20 High comp into auto civic eg
Old Dec 11, 2018 | 10:35 AM
Ej1d16y8's Avatar
Default B20 High comp into auto civic eg
Before I begin I want to go ahead and thank everyone who replies to my questions. I few days ago the engine in my civic went bad. So I decided it was time to swap my car since I had been wanting to for a while. I bought a Jdm b20b engine with low miles. What I want to accomplish when I’m done is the following. Properly working cruise control, ac & heat and power steering. Any tips, ideas and previous experience is welcome. My question to you guys is, what all do I need to complete this swap, not only a 5 spd swap but also b series swap. Do I buy a hydro trans or a cable trans. Since I don’t have ac at the moment, what compressor would I need? What bracket would it need? Would I be able to use the power steering pump from the b20 or use the one that comes with the car? For this swap I have the following: B20b engine, blox racing intake manifold, eBay header, integra 5spd pedals, axles, b series shift linkage and a chipped ecu. The engine is a obd2 so I bought the distributor and alternator adaptors as well as new injectors today.
Old Dec 11, 2018 | 12:23 PM
DaX's Avatar
DaX
Loved
Community Favorite
Default Re: B20 High comp into auto civic eg
You will need mounts. For auto, you may have to cut / weld the transmission bracket on the chassis.
Go with a hydro transmission.
Civic / D-series AC compressor. You will need the bracket from a DOHC-VTEC Del Sol.
Old Dec 11, 2018 | 12:45 PM
GIZZ - EXV's Avatar
Loved
Does your EG have a/c already?
In my area the cheapest thing to do is get a complete donor 94-95 integra for about $500. Get it for the transmission, axles, shift linkage, flywheel clutch, every last bolt you'll need will be there. You can use the integra ac compressor and bracket, not as hard to come by as the del sol vtec. Run that b20 on the stock integra p75 ecu, just bump the fuel pressure about 10 psi.
Like DaX said, you will need to cut and weld for the trans chassis bracket.
Old Dec 11, 2018 | 06:59 PM
eghatch9295's Avatar
Stancetard Hate Monger
you can use a conversion mount, you don't necessarily need to cut and weld
Old Dec 11, 2018 | 07:02 PM
Ej1d16y8's Avatar
I forgot to mention I have the auto to manual conversion mount sold by hasport. In my area people have wised up and part out integras. So I’m pretty much part hunting at the moment. What is an intermediate shaft? Do I need one?
Old Dec 11, 2018 | 07:06 PM
Ej1d16y8's Avatar
My car has no ac, the hoses end at the passenger side behind the headlight, so I believe that from the hoses back, everything is there
Old Dec 12, 2018 | 05:36 AM
tony_2018's Avatar
Fish Twig
ac system is not a requirement of swapping a b-series. please try again.
Ej1d16y8
Classic Hondas
Nov 22, 2018 09:28 PM
oldz6
10
Oct 25, 2015 11:04 PM
Bizarre
Aug 10, 2007 11:25 AM
allricedout
10
Mar 4, 2007 03:57 PM
dademax24
Oct 1, 2006 04:49 PM
