Honda CR-V & Element 2WD & 4WD Element & CR-V
99 honda crv p1399 code
Old Dec 10, 2018 | 06:43 PM
Prince Deucey's Avatar
Default 99 honda crv p1399 code
I have a 99 crv and keep getting a p1399 code. I've replaced air idle control valve, fuel injectors, spark plugs and wires, and distributor what can be the problem?
Old Dec 12, 2018 | 07:39 AM
UK-Kev's Avatar
Default Re: 99 honda crv p1399 code
You might want to check:-
1/ Could be a failing Ignition coil.
2/ Could be a lazy primary O2 sensor.
3/ B20 engine between 97 and 2001 are known to have a tightening valves problem.
andyjt
Acura TL, RL & ZDX
18
Oct 31, 2011 12:35 PM
lwautomotive
Oct 8, 2009 11:03 AM
ezra76
Oct 23, 2008 05:10 AM
