Hasport T bracket???
Has anyone bought and use the Hasport “t” bracket? Is it worth it? And I’ve read that if I use the 90-93 integra stock t bracket I’ll need to drill it to make the holes bigger, is that needed on the Hasport “t” bracket? Thanks
timmy timmy timmy
this is like me going to the shoe store and asking if all the shoes are the same ?
we need more info here
men or woman boy or girl
what size usa size uk size or mexico size?
get it ?
what car do you have
what engine do you have
what engine mounts do you have
are you cable trans or hydro
who told you anything about drilling?
please tell us more
get it ?
please tell us more
timmy timmy timmy
get it ?
please tell us more
get it ?
please tell us more
will now thats out of the way
lets clear the info up a bit
theres two t brackets for the 5 speed da intega from 90-93
the first is the cable one the 90-91
and the hydro one 92-93
you dont have to drill if you use the right bracket
and for you since your using a hydro trans that would be the 92-93 integra
also the 94-2001 integra also works as long as its the 5 speed one and not the auto
your first response was quite hilarious but we need to clear some things up with your second
there are NOT 2 different rear T brackets for 90-93 integra
in fact all 90-93 integra have 1 T bracket for all models. including automatic
i think where you got confused is 90-91 integra have small spline cable transmissions and 92-93 integra have big spline cable transmissions. which in the case of 92-93 big spline the internals are compatible with hydro transmission and vice versa
when installing a hydro transmission into the 90-93 integra you need to modify the factory rear T bracket by enlarging the 2 bottom holes with a 9/16ths drill bit
or we make a T bracket with the holes already done
also 94-01 integra rear T brackets do not work in the 90-93 integra chassis
yes 94-01 integra 5spd and auto T brackets are different so that part is correct
i stand corrected
my head was somewhere else
90-91 integra is obd0 92-93 is obd1
and i somehow took that info and used it on the transmissions
cable and hydro
