Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Electrical Question Parasitic Draw Fuse #29
Old Dec 1, 2018 | 05:53 PM
silentdub's Avatar
Default Electrical Question Parasitic Draw Fuse #29
Hey guys, I am looking in to a problem of a potential parasitic draw for someone. I was wondering if someone has the specs for normal draw of this 2014 Civic?
Right now I don't really see a problem, I checked the current draw between battery and terminal and after everything goes to sleep, I have a total draw of 10 - 20ma which isn't much. I isolated that 100% of the draw is for Circuit #29, fuse 29 which is the backup circuit.
When I put an ammeter in the circuit I get an initial draw of 1.15 amps, it then drops to .05/.06 then drops to about .01/.02. It mainly remains at .01/.02amps but I did see a 2 minute cycle where the draw rose to .05/.06 and saw that happen more than once.
Could someone provide me with what the normal draw is for this vehicle? 2014 Civic?
Does anyone have a list of the components on this circuit? Fuse #29?
Appreciate the help!
Old Dec 2, 2018 | 05:45 PM
silentdub's Avatar
Default Re: Electrical Question Parasitic Draw Fuse #29
I did some further testing, the vehicle .01/.02 draw is common and usual, shouldn't be a problem. Alternator is charging at 14.4V. I opened the battery and seems like I have a weak cell after testing it with a hydrometer and 2 cells seem to be low on fluid. The vehicle does sit for days at a time which may explain why it takes a while. The battery is a new replacement but that doesn't mean anything I guess.
nolimitlowrider
Mar 16, 2019 06:49 PM
d0wnShiFt
Jan 6, 2011 03:00 PM
mark2379
Sep 8, 2006 11:46 AM
Civic138
Jan 4, 2005 05:59 AM
rasta420
Nov 6, 2002 08:41 PM
