1993 Honda Civic VX - Tutorials/Progress/Knowledge/Maintenance
Old Nov 27, 2018 | 10:28 AM
triple beam's Avatar
10 Year Member
Default 1993 Honda Civic VX - Tutorials/Progress/Knowledge/Maintenance
I am no longer updating this thread, everything is on my website now: www.hondacivicvx.com
About Vehicle:
1993 Honda Civic VX
original d15z1 engine and transmission. 1.5 liter, 92hp, VTEC-E
320k miles
Fuelly Page
10 Year Member
Default UPGRADES
Upgrades:
-Highly recommend getting OsideTiger fuel injectors
no more lag, no more rpms going up and down, faster uphill, designed for the d15z1 specs!
4 hole mist spray instead of the original 1 line spray
these are available for many other engines
better fuel atomization
Old Nov 27, 2018 | 10:29 AM
10 Year Member
Default Maintenance
Maintenance:
Capacity amounts:
engine oil: 3.5qt w/filter change
transmission oil: 1.9 qt (once it starts pouring out of the drain hole, it's full)
every 50k:
-transmission oil flush
-coolant flush
vtec solenoid replacement gaskets:
upper gasket with screen: 36172-P08-005
lower gasket with screen: 15825-P08-005
just spray the solenoids with brake cleaner, and let it completely dry before re-installing
Coolant Maintenance:
proper thermostat: 19301-pza-305 (the d15z1 has different opening temp than other eg civics)
coolant temp sensor: 37870-pj7-003 (do not buy from ebay, they are from china)
coolant fan switch for radiator: 37760-p00-003 (do not buy from ebay)
temp sending sensor for your instrument cluster temp gauge (1 wire connection): 37750-ph2-014 (do not buy from ebay)
use Honda Coolant 50/50 from your nearest dealership
Air Intake:
air intake sensor: 37880-p05-a00
MAP sensor: 079800-4250
Oxygen Sensor:
NTK LZA-09-E1
I do not recommend buying the 24300
10 Year Member
Default Knowledge
Knowledge:
OEM rims: 9lbs = better mpg & acceleration
d15z1 is the only engine to come stock with oil cooler
Most efficient fuel injected engine
1992-1995 Civic's produced: 1,031,265. Civic VX: 12,088 (1%)
Old Nov 27, 2018 | 10:32 AM
10 Year Member
Default Re: 1993 Honda Civic VX - Tutorials/Progress/Knowledge/Maintenance
Tutorials:
Bluetooth cassette step by step
DIY GPS tracker with geofence alerts for your car! Only $6.40 a month!
What's needed:
1. US Mobile prepaid get the sim kit
2. 12v to 5v converter with USB
3. gps-server.net account
4. Unlocked phone (preferably google phone, im using nexus 5x h790)
Setup:
1. Download gps-server.net tracking app
2. Disable all apps
3. Turn off auto sync, remove google account
4. Disable background data for all apps except for GPS tracker
5. Change charging code in fastboot mode to enable automatic phone turn on when power is connected to phone, so that if the phone battery dies, it will reboot as soon as car starts. (Google for the one line code)
6. Activate US Mobile Prepaid, use the black sim as it uses Verizon network, which has better coverage than the white sim which uses TMobile. Select data only plan with 100MB (gps tracker will use less than 3MB daily)
7. Setup your gps-server.net account with IMEI number, email alerts for leaving zone, etc.
8. You can use gps-server app to view live tracking or use the website mobile version
9. Wire the converter to 12v power line in car and stash it somewhere.
Costs:
1. US Mobile 100MB $4.98/month
2. GPS-Server account $1.42/month
3. Total: $6.40/month or $77/year
Use code at activation: CUMUECX to get 50% off up to $10 on US Mobile:
https://www.usmobile.com/referrals?d...U9Vml0YWxpeQ==
12v to 5v converter:
https://www.ebay.com/itm/DC-DC-Conver...
Old Nov 27, 2018 | 10:35 AM
10 Year Member
Default Miscellaneous Upgrades
Miscellaneous Upgrades:
EG6 coin pocket:
Armrest:
EG6 Side Signals OEM:
1992-1993 Civic Si Door Panels (stripe pattern with door pockets, 94-95 Si has no stripe):
OEM Honda Civic stereo 3000 series (noise reduction, anti-theft, top upgrade for oem stereo honda accessories part #08A01-221-260
1994-1995 Civic Si Seats (rainbow pattern, 92-93 Si had stripe pattern seats):
Honda OEM window visors:
Last edited by triple beam; Apr 22, 2020 at 12:35 PM. Reason: Removing prohibited content that is not allowed outside of specific areas.
Old Nov 27, 2018 | 06:20 PM
94 Civic Si's Avatar
Premium Member
Loved
Community Favorite
Are any of these reserved?
Old Nov 28, 2018 | 09:41 AM
Relic1's Avatar
a hatch without rust *envy*
bringing back memories of my '92 back when I first bought it.
except you have a passenger mirror and are red to my teal. (and front corners, and duckbill, and I'm sure there are a few other mods that I can't see)
Old Nov 29, 2018 | 04:34 PM
tony_2018's Avatar
Fish Twig
Nice rims.
My HX rims got refinished. We removed the top paint and left the aluminum alone, we painted the inserts and the back of the rim black, I think the shop put on a decent amt of clear, or maybe its poly, but that thing stay bling.
Old Nov 30, 2018 | 08:31 AM
NVturbo's Avatar
O.G. triple O.G.
a clean, (mostly) stock Civic hatch is harder to find than most people think. Last one I had was about 10yrs ago. Like an idiot, I sold it after swapping in a D16Z6. Less than a month later, the new owner wrecked it.
Old Nov 30, 2018 | 11:34 AM
93grayeg's Avatar
Nice!
Old Nov 30, 2018 | 07:55 PM
Big1000's Avatar
Default Re: UPGRADES
Originally Posted by triple beam
Upgrades:
really interested in this. any chance you could post about any fuel savings?
also, I saw your rims for sale... why you selling?
Old Nov 30, 2018 | 10:07 PM
10 Year Member
fuel economey improved slightly! not much
the important thing is that these fuel injectors by OsideTiger change the performance of the engine by 500%. i am not kidding... i could barely make it up hills, had rpms go up and down, lag in acceleration. After installing these fuel injectors, it was like a factory engine 0miles! HIGHLY RECOMMEND!!!!
the rims are my spare set, i have no use for them
Old Dec 1, 2018 | 08:54 AM
Big1000's Avatar
Unfortunately the price is 150$ now on ebay . considering them still. I'm mainly going for fuel economy but better atomization couldnt hurt, especially during lean condition.
Old Dec 1, 2018 | 09:12 AM
10 Year Member
oh for your engine yea its 150, you wont be disappointed. let me know how it goes, if you do get them.
i would say 1-3mpg improvement. this isnt a miracle product where you gain 10mpg lol
Old Dec 1, 2018 | 02:28 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
I fail to understand how a fuel injector change increases performance and fuel economy on an otherwise stock D15B7 engine. Can you better explain please ???
Old Dec 1, 2018 | 03:19 PM
oneheadlight's Avatar
The description of improved performance would also occur if defective/bad injectors were replaced with fully functioning injectors. I had the same improvement by replacing my original injectors with new injectors (stock type, aftermarket replacement SMP brand). At the age of our cars, the injectors being replaced by ANYTHING new would be an improvement.
Old Dec 1, 2018 | 03:27 PM
eghatch9295's Avatar
Stancetard Hate Monger
d15z1, not d15b7. in addition to being new, i'm guessing the fuel coming from 4 holes vs 1 helps with the swirl under 2500 rpm, and being new will help with overall engine performance.
Old Dec 1, 2018 | 05:00 PM
Big1000's Avatar
better atomization. one of the challenges of lean burn is getting the gas to ignite in a lean condition. I would imagine atomizing the fuel better would help with ignition when you are running lean
Old Dec 1, 2018 | 08:46 PM
10 Year Member
watch this video about fuel injectors:
Old Dec 2, 2018 | 12:17 PM
Big1000's Avatar
they say visit osidetiger.com but the website doesnt work
Old Dec 4, 2018 | 08:53 AM
Relic1's Avatar
is this idea similar to the RDX 410cc injectors?
Old Dec 5, 2018 | 09:26 AM
Jon Petersen's Avatar
Did you say 500%? That's INSANE! May I ask: are there similar injectors for the d16z6 engine, and could I expect similar results?
Also I'm slightly jealous of your VX. Though it doesn't have AC, so I'm sorry about that.
Old Dec 5, 2018 | 12:23 PM
if you've ever driven a d15 and had the ac kick on, you wouldn't be so sorry about it lacking.
Old Dec 5, 2018 | 11:18 PM
10 Year Member
they have one for your engine even a 12 hole spray version for your d16z6. only pros to this, no cons at all, and very very easy to install too!
i actually do have a/c. i have to recharge it with "MAXI FRIG 12a" bcuz my system is the old R12 system.
