Why is my car sputtering upon acceleration even after head swap
Old Nov 20, 2018 | 08:05 PM
D.j. Holley's Avatar
Default Why is my car sputtering upon acceleration even after head swap
My original head had a burned valve horrible idle whole car shook hard to start horrible sputter on acceleration cyl 1 and 3 was at 180psi cyl 2 at 120 and cyl 4 and 30 burned valve was on cylinder 4 side Ofcourse changed head got a little better idle, acceleration is not horrible as it used to be but CEL is still on and blinks while acceleration or idling (misfiring) it sputters a lot I can hear it I changed the spark plugs again with the new head and idle got better by a lot acceleration like I said got a lil better easier to start up starts up way faster I haven’t changed the spark plug wires tho but they are fairly new I bought them a month ago. Maybe misfire ruined the plugs too? Idk. I tried unplugging fuel injector and wire on all cylinders the engine changed except cyl 4 it stayed the same like it always did. What else could it be? Firing order? Dizzy timing? Cuz I threw my old dizzy on the new head so idek if it’s timed right. New timing belt water pump tensioner installed at TDC HELP
Old Nov 20, 2018 | 09:42 PM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
Default Re: Why is my car sputtering upon acceleration even after head swap
Check mechanical timing, check ignition timing.
Check compression and and do a leak down test as well.
It’s cheap enough to replace the plugs if they are fouled.
Check the CEL and what codes are popping up.
Old Nov 21, 2018 | 12:26 AM
CEL codes are cylinder 2,3,4 are misfiring compression with the old head with burned valve was 180 120 180 30. I’ll do another one with new head. Mechanical timing is good I think cuz I installed a new timing belt and everything was lined up at TDC. I think my ignition timing has to be set because I had to remove the distributor from my old head to my new head and I basically just bolted it on so it may be off. I’ll also try the leak down
Old Nov 21, 2018 | 02:00 AM
muellersfan's Avatar
Reset ECU to clear old codes.
Run engine until CEL turns on and stays on.
Post the new codes stored in ECU.
Old Nov 21, 2018 | 05:03 AM
tony_2018's Avatar
Fish Twig
did you even replace the head gasket?
mustang66dude
Honda CR-V & Element
10
Oct 22, 2011 10:37 PM
v8killaz
Jun 23, 2011 03:22 PM
blackmugensivic
Jul 23, 2008 05:51 PM
Drizzo
Jan 8, 2006 08:26 PM
