Coolant: Regular or Honda/Nissan for 95 Civic?
Old Nov 15, 2018 | 09:09 PM
Jon Petersen's Avatar
Post Coolant: Regular or Honda/Nissan for 95 Civic?
I've got a coolant leak on my fast idle valve on my 95 Civic. I've had to add coolant before because of this, and I've just used Prestone brand antifreeze. But today, when I went to go buy some at Walmart, I saw there was Prestone Nissan/Honda coolant. Do I need to use this? I was pretty sure regular coolant was fine, but I'd like some input on this issue.
Thanks.
Old Nov 16, 2018 | 02:35 AM
tony_2018's Avatar
Fish Twig
Default Re: Coolant: Regular or Honda/Nissan for 95 Civic?
Nissan is starting to use a coolant with similar color to Honda blue coolant. But I have not confirm with testing
Old Nov 16, 2018 | 04:55 AM
Chance EG's Avatar
Honda, Nissan, and I actually think Volkswagen as well.
Old Nov 16, 2018 | 05:01 AM
muellersfan's Avatar
Buy the coolant below at Advance Auto using a 25% off coupon code obtained from the DealsPlus website.
https://shop.advanceautoparts.com/p/zerex-asian-vehicle-red-ready-to-use-antifreeze-coolant-1-gallon-675130/11046680-p?c3ch=PLA&c3nid=11046680-P&adtype=pla_with_promotion&gclid=CjwKCAiA8rnfBRB3 EiwAhrhBGttXMFI_b-EbFn5H2l6WaIVfxvIjKyS2Umy4d2j_7j8f6qiNsU9QoRoC3J4Q AvD_BwE&gclsrc=aw.ds
Old Nov 16, 2018 | 05:35 AM
mk378's Avatar
There are two general types of coolant: the old silicate based conventional green (which is becoming hard to find in stores), and the newer organic acid (HOAT) based coolants specified for newer cars and "all makes all models". (Then there's also Dexcool... but that should only be used in GM cars). You can use either silcate or HOAT in a 1995 Civic but do not mix them. Flush out the Prestone if you're going to run "Asian", "Honda", "All Makes All Models" etc. Those are all HOAT not silicate.
Old Nov 16, 2018 | 08:22 AM
NVturbo's Avatar
O.G. triple O.G.
Not VW/Audi. They require different coolant than the typical one found everywhere. When I did the water pump replacement, I picked up some Pentosin 12++ coolant from the nearby Advance Auto Parts.
Old Nov 16, 2018 | 12:01 PM
tony_2018's Avatar
Fish Twig
Interesting..
Old Nov 18, 2018 | 08:27 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
If I may.....
What happens if you mix the two and run it for any serious length of time?
Old Nov 24, 2018 | 09:25 AM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
Originally Posted by TomCat39
If I may.....
This.
Old Nov 24, 2018 | 09:27 AM
tony_2018's Avatar
Fish Twig
lol, even though it was a serious question.
Old Nov 24, 2018 | 01:24 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Originally Posted by deschlong
Yeah I kinda figured it would be the above, but was wondering if anyone knew what happens techinically. Does it cancel out cooling properties making it worse than straight water? Does it make it go immediately acidic to start eating away at all the parts?
What bad things happen when you mix the two coolant types together?
Old Nov 24, 2018 | 04:53 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Nevermind, it appears nothing drastic happens overall except reducing the length of life the coolant is good for:
How antifreeze and coolants have evolved
Inorganic Acid Technology (IAT) is the chemical foundation for the original green or blue antifreeze. IAT contains either ethylene glycol or propylene glycol and is mainly built up with silicate or phosphate additives to increase its compatibility with metal cooling system components. The generally recommended replacement interval is every year.
What do IAT and OAT mean?
As we have seen, Inorganic acid technology (IAT) is the chemical composition for the traditional green, yellow or blue antifreeze.Organic acid technology (OAT) on the other hand is a Long Life Coolant usually made of ethylene glycol and is commonly used in Europe. It also has a vastly superior recommended replacement is 5 years or 240,000km. Hybrid Organic Acid Technology (HOAT) is a combination of IAT and OAT with nitrites and actually existed prior to the development of OAT technology. The generally recommended replacement interval is 3 years or 240,000km.
Can you mix antifreeze?
It is best to use the same type of coolant originally used in your vehicle, or the vehicle manufacturer’s recommendations. According to experts within the industry, if you don’t know what coolant is in the vehicle and you add another brand, nothing bad will occur. But if the mixture of the technologies is close to 50%, the effectiveness of each coolant’s inhibitor package is affected. In general, if mixing coolants, the recommended coolant change period will fall to that of the shorter life coolant.
The above pulled from here.
Flipnotize21
Honda Civic (2006 - 2015)
Jan 19, 2007 07:31 AM
Rvrrnr99
Jul 12, 2003 07:02 PM
T_Rex
Nov 9, 2002 06:21 PM
pucho
Oct 5, 2002 02:18 PM
