Troubleshooting:2006 Honda Civic si coupe ac compressor won’t shut off
Old Nov 14, 2018 | 04:55 AM
Bigtroy12's Avatar
Default Troubleshooting:2006 Honda Civic si coupe ac compressor won’t shut off
2006 Honda Civic si coupe ac compressor won’t shut off only when you turn the button off
Old Nov 14, 2018 | 06:23 AM
muellersfan's Avatar
Default re: Troubleshooting:2006 Honda Civic si coupe ac compressor won’t shut off
Does it turn off if you unplug the dash heater/AC control unit?
Old Nov 17, 2018 | 06:06 AM
thisguyaves's Avatar
Default Re: Troubleshooting:2006 Honda Civic si coupe ac compressor won’t shut off
Not sure I understand, " only when you turn the button off"... do you have it on defrost? Most will default to ac on to prevent interior window fogging.
Old Nov 18, 2018 | 04:44 AM
DaX's Avatar
DaX
Loved
Community Favorite
You may be low on refrigerant. Your system can be at a "sweet spot" where it is pressurized enough to not trip the dual pressure switch (I think 33 psi), but not have enough refrigerant to cool the evaporator to below the cutoff temperature (somewhere around 35 degrees). This will cause the compressor to just keep running.
HondaNoviceMan
Honda Civic (2006 - 2015)
Jun 26, 2018 02:28 PM
MachoRP
Jun 13, 2017 12:06 PM
tontontons
Jul 14, 2016 01:18 PM
David Guevara
19
Apr 9, 2016 06:44 AM
