Troubleshooting:2006 Honda Civic si coupe ac compressor won’t shut off
Re: Troubleshooting:2006 Honda Civic si coupe ac compressor won’t shut off
Not sure I understand, " only when you turn the button off"... do you have it on defrost? Most will default to ac on to prevent interior window fogging.
You may be low on refrigerant. Your system can be at a "sweet spot" where it is pressurized enough to not trip the dual pressure switch (I think 33 psi), but not have enough refrigerant to cool the evaporator to below the cutoff temperature (somewhere around 35 degrees). This will cause the compressor to just keep running.
MachoRP
06-13-2017 12:06 PM
David Guevara
19
04-09-2016 06:44 AM
