F20b swap my 1992 prelude won’t start
Old Nov 13, 2018 | 04:11 AM
Roberts71's Avatar
Default F20b swap my 1992 prelude won’t start
So I swapped an F20b into my 92 prelude and it won’t start. None of the injectors have any power. Haven’t checked spark. I swapped all the OBD1 stuff onto this motor. So it’s conpletely OBd1. But still won’t start. Any help please
Old Nov 14, 2018 | 04:07 AM
TimiK's Avatar
10 Year Member
Default Re: F20b swap my 1992 prelude won’t start
youre not giving enough info
what parts you have changed during the swap, what ecu youre using, what engine harness... and so on
Old Nov 14, 2018 | 04:55 PM
Roberts71's Avatar
P28 ecu with F20b chip. Dash harness is a h23. Everything else is from the H22
Old Nov 15, 2018 | 08:40 AM
Aradin's Avatar
Premium Member
What injectors are you using? Did you retain the resistor box?
Old Nov 15, 2018 | 04:44 PM
Roberts71's Avatar
Obd1 Injectors from the h22. And yes resistor box is still there. I also have no spark either
Old Nov 16, 2018 | 08:08 AM
Aradin's Avatar
Premium Member
If you have no spark and no injector pulse, it sounds like you may possibly have a disconnected engine harness plug. It could be a bad ECU also. Can you verify that the ECU works? Does the CEL stay lit when you put the key in the "run" position?
Bc1r6x
Oct 6, 2011 05:54 AM
buffgsr
13
May 1, 2010 02:12 PM
md88hfcrx
Jun 6, 2007 07:12 PM
camboMONK
14
Dec 8, 2005 08:11 AM
civichbsmn
Jun 7, 2003 04:17 PM
