Oil pressure
Old Nov 9, 2018 | 12:53 AM
Scoberdoo's Avatar
Default Oil pressure
What is the Normal/healthy oil pressure at idle and at speed for an F22B2 , I've read other places typically its about 10psi per 1000rpm.
Old Nov 9, 2018 | 04:19 AM
shipo's Avatar
Default Re: Oil pressure
Sounds about right, assuming the engine oil is fully warm. That said, the number is likely to be lower for engines with a few hundred thousand miles on the clock. Even if the pressure is a little low, that in and of itself is no cause for alarm.
Old Nov 10, 2018 | 12:26 PM
MAD_MIKE's Avatar
MM Gruppe B
Per FSM
Engine Oil temp @ 80°C(176°F)
Idle- 10Psi minmum
3Krpm- 50Psi minimum.
OHC engines require a bit more pressure than OHV so the 10psi/1k rpm does not follow for our engines.
Old Nov 12, 2018 | 07:55 AM
Scoberdoo's Avatar
Thanks for the info Mike
trulyshavedintegra
Dec 9, 2012 05:06 AM
ProjectBB6
Sep 16, 2009 02:18 PM
dragvixen
Jul 10, 2009 11:20 AM
MtJavnk
Sep 18, 2004 01:37 PM
CaNaBiS
Feb 3, 2004 01:30 PM
