Having trouble keeping spark as well as fuel. Car will run if i spray starting fluid but injectors not firing.
Im using a f22b harness with a obd1 to obd2b harness adapter .
Insane shaft swap axles
inovative swap mounts
stock trans with modified shift box
msd blaster ss coil pack
Spaced and port matched intake and exhaust
421 header ( cheap until running )
A few egr sensors deleted (all unneeded for application)
