Water pump failed?? Need advice.
Old Nov 3, 2018 | 04:29 AM
Michael Butts's Avatar
Default Water pump failed?? Need advice.
I have a 96 civic ex. The radiator cracked along the top, i replaced it. Then after when i started the car, the top hose started swelling up and there was a lot of pressure in the system. The cooling fan did not turn on. I think it is the water pump not working.
Old Nov 3, 2018 | 06:02 AM
muellersfan's Avatar
Default Re: Water pump failed?? Need advice.
Did you top off the radiator and reservoir with coolant and then do a thorough cooling system bleed?
Old Nov 3, 2018 | 06:13 AM
yes, but i think it is the head gasket now. It wont crank, and just from attempting to crank, there is pressure in the radiator. Am i right?
Old Nov 3, 2018 | 06:14 AM
Was the dash temp gauge pegged at the full HOT red zone when the radiator failed?
Old Nov 3, 2018 | 06:19 AM
I think the thermostat has been stuck open, so the temp has always been low. But the temp did rise the first time it started after i replaced the radiator. I turned it off when i saw the top hose swelling. It hasnt cranked since.
Old Nov 3, 2018 | 07:39 AM
Old Nov 3, 2018 | 08:05 AM
since the thermostat is always open, the "normal" running temp is always at the bottom of the cool gauge. So after the radiator replacement, the temp went up to the mid point on the gauge. That would probably be at the hot end.
Old Nov 3, 2018 | 08:56 AM
White_EG1's Avatar
Operating temp is supposed to be at that level. Try a new rad cap, and bleed the system properly before you jump to conclusions.
If it’s a d series you have to loosen the bleeder bolt on the upper hose too.
And if it’s not cranking now that has about nothing to do with anything that you mentioned. Fix the no crank first.
Old Nov 3, 2018 | 09:02 AM
I will try the bleeder bolt and bleed the system.
Old Nov 3, 2018 | 09:07 AM
6th generation = no bleed bolt
Old Nov 3, 2018 | 09:13 AM
Radiator cap should release pressure to the reservoir, so consider that the cap is bad.
Old Nov 3, 2018 | 09:16 AM
The car still wont crank. But pressure still builds in the new radiator from attempting to crank.
Old Nov 3, 2018 | 09:21 AM
Fyi
Cranking = starter turning engine
Old Nov 3, 2018 | 09:22 AM
Compression test the cylinders
Old Nov 3, 2018 | 03:37 PM
eghatch9295's Avatar
Stancetard Hate Monger
pull the cap off and crank what happens?
Ryebread1974
Sep 24, 2018 04:24 PM
hondadnoh
Jan 13, 2014 04:13 PM
carrollrucker
Aug 28, 2013 11:09 PM
accord2civic2prelude
Dec 10, 2009 09:19 PM
dbman96
Aug 8, 2001 02:24 PM
