Ex d16a6 distributor
Old Nov 2, 2018 | 08:31 PM
d_seriesef's Avatar
Default Ex d16a6 distributor
I’ve got a d16a6 I had a bad ignition coil, replaced it. Then the control module went out. So I went and bought a new dizzy. When I installed the dizzy the teeth snapped off. Any ideas? I’m lost????
Old Nov 3, 2018 | 04:17 AM
DaX's Avatar
DaX
Loved
Community Favorite
Default Re: Ex d16a6 distributor
Post a picture of what you're describing. The teeth on what snapped off?
Old Nov 3, 2018 | 02:35 PM
d_seriesef's Avatar
The teeth on the distributor shaft that goes to the cam shaft....
Old Nov 5, 2018 | 12:05 PM
4drEF's Avatar
Keyboard Humorist
The two tabs that go into the slot on the cam can only go in correctly one way.
Sounds like you maybe had it rotated 180 degrees and tightened it in place which snapped them off.
Old Nov 5, 2018 | 12:46 PM
Free Man's Avatar
5 Year Member
this is indeed what happens when you install it 180 degrees off.... luckily, you should be able to install the shaft from your used dizzy into your new one and try it again.... just be very meticulous with the internals on your new dizzy.... take pictures if you have to, so you can put it all back together correctly
Old Nov 7, 2018 | 03:00 PM
d_seriesef's Avatar
So I had someone else remove the dizzy. How can I make sure that I am putting it on the correct way?
Old Nov 7, 2018 | 05:30 PM
d_seriesef's Avatar
Thank you everyone I got hooked up
PabloM
Oct 11, 2013 04:21 AM
GrnZ
Mar 27, 2008 07:33 PM
racekar
Oct 19, 2004 09:32 PM
theslugbug
Dec 12, 2003 10:03 AM
austrian type-R
Jul 25, 2002 03:41 AM
