Honda CR-V & Element 2WD & 4WD Element & CR-V
99-00 Civic power window motor fit 98 Crv?
Old Nov 2, 2018 | 10:48 AM
WAUKEENEM1's Avatar
Default 99-00 Civic power window motor fit 98 Crv?
As the title says...I would like to know if a window motor from a 99-00 civic will work on a 98 Crv.
driver side window wont go down...in the process of diagnosis the issue
Thnx
Old Nov 2, 2018 | 11:27 AM
tony_2018's Avatar
Fish Twig
Default Re: 99-00 Civic power window motor fit 98 Crv?
Have you cross reference part numbers?
Old Nov 2, 2018 | 03:51 PM
WAUKEENEM1's Avatar
Have not but looked on ebay an it says 92-95 civic n 98-02 prelude are the same...maybe 96-00 civics are different
i plug the 99 civic motor to the crv wire hardness and still no go...
tested the wire hardness and it got power on both side of connectors
so, im thinking the switch is good...probably bad motor, ground or another wire
Also, the two wires i test only comes on my test light when i pressed the window switch down not up
Thomas Kalita
Honda Civic (2006 - 2015)
Jun 7, 2018 08:06 PM
nmb16a
Jun 30, 2010 01:36 PM
esdrunkcuz562
Honda Civic (2001 - 2005)
Aug 24, 2009 10:18 PM
Slepton
Feb 9, 2009 11:48 AM
Integras N Civics
Feb 14, 2005 06:12 PM
