How to remove A/C from 90 Si
Old Nov 13, 2002 | 04:20 PM
uncleben's Avatar
Default How to remove A/C from 90 Si
What are the steps to completely moving the A/C from a 90 Civic Si hatch? If there is a howto somewhere then by all means please send me the link. Otherwise, be as detailed as possible. Thanks!
Old Nov 13, 2002 | 04:46 PM
uncleben's Avatar
Default Re: How to remove A/C from 90 Si (uncleben)
okay honda-tech search sucks my nuts... i did a search and it didn't find it at first, i'm assuming partly because HT won't search words with 2 characters or less (like ac)... so next i did a search of the archive for just the word "remove" and skimmed through 10 pages and found this:
https://honda-tech.com/zerothread?id=212174
sounds like i first (duh) need to take it somewhere to have the freon removed if I'm going to be enviromentally friendly. (i guess i can) then i can remove the hoses, and compressor from the block, and remove the condenser in front of the radiator.
sound about right?
Old Nov 13, 2002 | 06:04 PM
BreakStuff's Avatar
New User
You got it bro... look at the location of the a/c compressor and remove all attached components including wire harnesses, a/c compressor, hoses, condensor, condensor fan, receiver/dryer unit....
Do not go beyond the firewall.. this is the evaporator unit and its housing needs to be intact for the HVAC(- the a/c) to work effeciently....
josups
14
Jun 2, 2024 09:15 PM
95lsvtech
Apr 1, 2007 07:48 PM
lude98SH
Jul 2, 2006 04:51 PM
redDAinteg
Feb 19, 2006 01:33 PM
GRM Scott
Apr 21, 2005 07:51 PM
