Dash lights & License plate lights not working.
Old Oct 31, 2018 | 01:59 PM
EfSedan1991's Avatar
Default Dash lights & License plate lights not working.
Hey all. I have recently manual converted my 1991 Ef sedan. I have changed over to the manual cluster and now my license plate lights and dash lights aren’t going. I have checked and replaced fuse No. 8 and has not changed anything. Any insight or help would be much appreciated. Thanks
Old Oct 31, 2018 | 02:10 PM
muellersfan's Avatar
Default Re: Dash lights & License plate lights not working.
Does voltage reach fuse 8 with the light switch on? If not, test the light switch.
Old Oct 31, 2018 | 02:28 PM
Yes. It is receiving power. They also all worked before the manual conversion
Old Oct 31, 2018 | 02:39 PM
What does not work?
Do the clock, radio light, and taillights work?
Old Oct 31, 2018 | 02:42 PM
Yes they do, as far as I am aware the only ones not working are all dash cluster lights and license plate lights.
Old Oct 31, 2018 | 02:50 PM
There's a broken wire in the circled area.
Old Oct 31, 2018 | 03:05 PM
Are you sure? As problem only occurred after manual converting and changing to manual dash cluster. However I can check. Where would I find that wire?
Old Oct 31, 2018 | 03:09 PM
Do you have a better alternate diagnosis that also fits with all of the information you've provided? Evaluate diagnostic information without any preconceived notions.
Trace the Red/Blk wire.
Old Oct 31, 2018 | 03:11 PM
I never said you were wrong. Was just curious. As I asked where could I find that wire that may be broken?
Old Oct 31, 2018 | 03:18 PM
Study the crude circuit diagram. It's the Red/Blk wire that runs between the clock or radio and the cluster. You can use a multimeter to verify or refute a lack of continuity between these points on the Red/Blk wire. If verified, just run a new wire between the points rather than trying to locate the break.
shumphries1018
Sep 17, 2018 05:21 AM
Integra4lyfe069
43
Oct 11, 2017 09:57 AM
88aeFC3S
Jan 3, 2010 11:38 AM
slob20ef
Mar 30, 2009 05:43 PM
NatedoggAZ
Feb 10, 2006 11:00 AM
