94 Honda Civic si B20vtec
Old Oct 30, 2018 | 04:48 PM
Nene Coss's Avatar
Default 94 Honda Civic si B20vtec
Hello everyone. I have a 94 civic si hatch with a b20vtec in it. I bought it off a friend and it was running but idled under normally. My friend told me that it needs to be tuned since it has a type r head and cams. I was driving the car around here and there and I never was able to take it to get tuned. One day the car start sputtering on me when I would’ve drive at about 60 mph and it died. The car didn’t start back up after that. I ran the engine codes because my engine light came on, and it came up as a map sensor. I replaced the map sensor and also the tps sensor. The car starts but won’t stay on. I can rev the gas and it’ll help it stay running but still won’t help it stay on. It eventually shuts off. I’m not sure if it’s loss of fuel or what but I could use your guys help to figure out what it could be before I start throwing money into it.
Old Oct 30, 2018 | 04:54 PM
muellersfan's Avatar
Default Re: 94 Honda Civic si B20vtec
A map sensor code does not necessarily mean the map sensor is bad.
What specific map sensor code was thrown?
Is the original code or a new CEL code(s) now thrown?
Old Oct 30, 2018 | 04:59 PM
Nene Coss's Avatar
it was 3 fast flashes of the CEL that was thrown. It’s still just flashing 3 fast times.
Old Oct 30, 2018 | 05:02 PM
It's an electrical problem in the MAP sensor circuit.
What ECU is running the B20?
Do you have a multimeter? If so, post pics of the map sensor connector and its three wires.
Old Oct 30, 2018 | 05:05 PM
Nene Coss's Avatar
Its running a p28 with a 2 step so it has to have some type of tune. And no I don’t have a multimeter at the moment.
Old Oct 30, 2018 | 05:09 PM
Before you have a tune, you must fix code 3. You can fix code 3 yourself or pay money to a mechanic. If you prefer to fix it yourself, purchase or borrow a multimeter to do proper diagnostics.
Old Oct 30, 2018 | 05:13 PM
Nene Coss's Avatar
Ok. Once I purchase a multimeter what do I do?
Old Oct 30, 2018 | 05:16 PM
Start here:
Post pics of the map sensor connector and its three wires.
Old Nov 2, 2018 | 01:13 PM
Nene Coss's Avatar
Start here:
Old Nov 2, 2018 | 01:15 PM
Nene Coss's Avatar
I uploaded the pictures
Old Nov 2, 2018 | 01:18 PM
Nene Coss's Avatar
I believe the pictures went to my gallery how do I get them to be on the comments ?
Old Nov 2, 2018 | 05:54 PM
Freedo_Civegra's Avatar
Click the reply tab, then click the icon next to the smiley.
Old Nov 2, 2018 | 06:07 PM
Nene Coss's Avatar
Start here:
Nene Coss's Avatar
Thank you.
Old Nov 2, 2018 | 07:22 PM
Turn key to ON(II).
In the wire harness connector, use the middle Grn/Wht wire as ground to measure voltage at the (1) Wht wire or (2) the Yel/Red wire.
Post the two voltage readings.
tek9_ej2
Apr 10, 2010 05:13 AM
Kuppa
Sep 26, 2009 04:11 PM
chrysler kid
Sep 28, 2004 07:24 PM
slowazzhatch
Jun 1, 2003 07:42 PM
