Accord V6 with a weird charging ... problem?
OK so I've pulled out enough hair trying to chase down what may not even be an issue with my wife's 2010 Accord. So I figure it's time to enlist the minds here.
A few weeks ago, her alternator went out. She managed to make it home, but her battery was nearly dead. So I replaced both just to be sure since the battery was 3 years old anyway. And while everything seems fine as far as the battery staying charged and all accessories working fine, every so often as she's coming to a stop the battery light will briefly come on. It always goes right back out a few seconds later (without the engine speeding back up).
Things I have checked...
1. Battery connections are very clean and very tight
2. All terminals, both + and -, are also clean and tight
3. Resistance from the alternator lug to the + terminal measured at < 3 Ohms
4. Measured voltage at the battery at idle with the headlights, windshield wipers, defroster grid, and blower fan all on high. It never went below 14.15v
My working theory was that the voltage regulator in the alt was bad out of the gate. However since then, I've found several people with the exact same story INCLUDING one guy who personally rebuilt his alternator. So now I'm not so sure. Now I'm wondering if maybe Honda just put tighter constraints into their expectations of how quickly the alternator output will be adjusted than most rebuilt alternators can meet? I dunno ... I got nothing here. Because once again, everything seems fine. The battery is always topped off. It cranks up fast as ever. None of the accessories seem to be struggling for power. If it wasn't for that light, I would never even suspect anything amiss.
thanks in advance
thanks in advance
Dump it for a refund,if possible. Buy Honda, Denso or Hitachi only, youll have less headaches and frustration(Bosch is a distant 4th on that list)
Ill stick with my original assumption and assume the alternator is bad.......
But given that literally the only symptom is that damned light, do you truly think it's "bad" or just slightly out of honda's specs? I'm not trying to be argumentative ... just playing devil's advocate here. In your opinion, is my wife driving a timebomb, or is she just going to have to deal with a blinky light for the next 8 years?
LoL, the light is on for a reason(in the less PC days we called those lights the "idiot lights", for good reason)
If getting it repaired properly is not in your wifes best interest,just let it go and let the chips fall how they will.....
lizp
Jan 3, 2011 04:36 PM
jdm5ghb
Jan 10, 2004 06:09 PM
