I can't figure out what ECU jumper I need 92 civic swap
I swapped out my stock motor in my 92 Civic with a b20b and I'm running a p75 ECU I just don't know if I need an obd2a to OBD1 jumper or an OBD1 to an OBD2a help me please!
which ECU version do you have? (OBD1, OBD2a or OBD2b)
which engine-to-ECU harness did you use?
which standard would you like to use?
92 means emissions are not a concern (unless you are in cali)
I'd go with an OBD1 ECU with a chip to run it right.
the OBD1 P75 for the LS can be chipped to add some fuel for the larger displacement.
sohcvtec66
Aug 23, 2004 06:55 PM
