is it possible a resistor o2 with obd0?
Old Oct 25, 2018 | 01:51 AM
ochumi's Avatar
Default is it possible a resistor o2 with obd0?
Hi i want to ask you if itīs possible to connect a lambda with heater resistor and how it will connect
thanks
Old Oct 25, 2018 | 10:14 AM
4drEF's Avatar
Keyboard Humorist
Default Re: is it possible a resistor o2 with obd0?
sort of... not really.
You can hook the heater up to 12v and it will get hot, but that isn't how it operates with an ECU that is intended to have have a heated O2 sensor.
ECUs that have the 4 wire O2 not only power the heater, but also monitor the resistance of the heater circuit.
there is no temperature sensor in the O2 sensor, but the resistance of the heater circuit will change with temperature.
The ECU does constantly monitor this resistance and supplies power accordingly to maintain a consistent heater temp.
houseofgrafix
Aug 16, 2010 08:49 AM
EF9ZC
Mar 28, 2006 10:48 AM
rice4life
Jun 26, 2003 03:39 PM
filetofit
Feb 16, 2003 01:41 PM
gtpilot
Dec 12, 2002 12:27 PM
