d16z6 turbo help
Old Oct 20, 2018 | 06:12 PM
Alex7290's Avatar
Icon4 d16z6 turbo help
whats up guys! i have a 1994 honda civic 4 door with a d16z6 in it and got a turbo kit for it and a few extras such as 450cc injectors.. other than welding a piece onto my oil pan for the turbo oil return line, am i able to install and run the kit on my engine with a stock ecu? i will eventually order a new p28 ecu that is chipped from a tuning shop but i was just wondering if i could still have fun before then and install the kit on my car now without it thanx. and yes just to be safe im only going to be running 6 psi boost until i build my engine.
Old Oct 21, 2018 | 05:52 AM
turboLScrx's Avatar
25 Year Member
Loved
Community Favorite
Default Re: d16z6 turbo help
‘you can go old school and run a fuel pressure riser and a missing link to trick the map sensor, i ran mine like that for many years before better ways came around. You will have to keep the stock injectors until you chip the computer which is why the fuel pressure riser is needed. The price you spend on a riser and a missing link will probably just about get you a chipped ECU and then you can run the larger injectors. Point is..... just do it right
93shbox
Oct 11, 2014 05:34 AM
thisguy2012
Mar 26, 2012 10:22 AM
honda_racer1986
May 4, 2007 04:31 PM
vi3t0rious
Apr 22, 2005 02:58 AM
fafsa
Dec 18, 2004 12:08 AM
