radio installation issue on 97 honda civic
Old Oct 16, 2018 | 02:58 PM
Josh_Scranton's Avatar
Default radio installation issue on 97 honda civic
1997 honda civic dx radio problem. just got the vehicle 2 weeks ago and it had an aftermarket radio installed. i purchased a newer radio last week and tried to install it today but it would not turn on. i tested the radio on the car battery first to see if the radio actually works and it does. secondly i used a test light to find power. the yellow w/ red strip ignition wire has no power at all when vehicle is in the run position. the 12v constant wire, white w/ blue stripe only has power when the vehicle is in the run position. third i checked for a ground and the black wire is working and illuminated the test light but the white w. blue strip wire lit dimly as well which makes me believe it has a short since it illuminates dimly with both test light tests. i have a solid red wire and a red w/ black strip wire that also lights up when searching for a ground but not with power, those 2 wires are aftermarket i believe , maybe for an amp or subwoofer. I checked the fuse under the hood, the 7.5 amp, and it was blown. I replaced and no luck. Under the dash i checked as well and no blown fuses. I am unsure what to try next. possibly grab a multi meter and see if the constant is getting 12v and check to see if the ignition wire is getting any juice too. if anyone has any advice or links to wiring diagrams please help me out!
thanks, josh
edit : fixed the issue, was another fuse i didnt check
Old Oct 17, 2018 | 01:22 PM
thisguyaves's Avatar
Default Re: radio installation issue on 97 honda civic
I gotchu fam
Power:
Radio 12V white/blue + radio harness
Radio Ground black - radio harness
Radio Ignition yellow/red + radio harness
Radio Illumination red/black + radio harness
Speakers:
Left Front Speaker (+/-) blue/green - gray/black +,- radio harness
Right Front Speaker (+/-) red/green - brown/black +,- radio harness
Left Rear Speaker (+/-) blue/yellow - gray/white +,- radio harness
Right Rear Speaker (+/-) red/yellow - brown/white +,- radio harness
Use a multimeter, not a light. Much more accurate. Might as well take this time to polish and make a new ground too
jayj99crv
12
Sep 18, 2018 10:07 AM
Vladglad
Aug 1, 2015 09:52 PM
MrBryan
May 28, 2007 04:27 AM
T04-Terror
Audio / Security / Video
Jul 22, 2003 09:12 AM
speedevo
17
Mar 17, 2003 06:10 AM
