AM Signal booster
Old 10-19-2018, 12:34 PM
SwissSnowTiger's Avatar
Default AM Signal booster
I was told by a car stereo installed that the stock radio is paired with the antenna imbedded in the rear window, and that poor reception may be due to an AM signal booster that has gone bad...is this a part that can be replaced?
Old 10-20-2018, 06:43 AM
thisguyaves's Avatar
Default Re: AM Signal booster
Yes, but at that point you might as well just get a new antenna installed after the fact. there are small sticky antennas that can mount on most windows and trim pieces that will do the job.
Old 10-20-2018, 10:30 AM
How easy is it to plug the antenna into the radio? It seems impossible to get at the radio at all...I know of those antennas, I used one in an old car...
Old 10-20-2018, 10:51 AM
Depends on the car, but older hondas are usually pretty easy. My 02 coupe only require removal of 2 screws, and my Si didn't require removal of any. Just make sore you get an antenna or booster with the correct plugs.
Old 10-20-2018, 11:01 AM
Mine is an ‘06, does that make it worse at getting to the connection? And what type of plug in does that year’s radio have?
Old 10-20-2018, 02:38 PM
an 06... what? Civic, crv, element, odyssey, accord... Call a local car audio installation shop and they'll be able to line it all up, or check metra.com for the antenna type
97honda_accord
03-29-2015 08:24 PM
solex
Honda Civic (2001 - 2005)
10-01-2010 05:08 AM
<StevieG>
03-07-2008 10:29 AM
Slipknt777
08-02-2004 09:31 AM
mattL
11-05-2002 02:53 PM
Quick Reply: AM Signal booster
