which one is power and ground???!
Old Mar 13, 2003 | 06:52 PM
speedevo's Avatar
Default which one is power and ground???!
could someone tell me on 00 accord the rear speakers which one is ground and power? there is a red wire with yellow stripe and a brown wire with white strip, thanks.
Old Mar 13, 2003 | 07:00 PM
vteg's Avatar
New User
Default Re: which one is power and ground???! (speedevo)
On my teg the brown and greys are grounds for the speakers, from memory.
Old Mar 13, 2003 | 07:12 PM
BangAccord's Avatar
Default Re: which one is power and ground???! (vteg)
I'm pretty sure the Red wire is the live one...but dont take my word for it
Old Mar 13, 2003 | 09:41 PM
TurboBumblBee's Avatar
browns and greys are negative.. red and blues are positive.. im pretty sure of that.. if your not sure test the speaker using a 9volt battery
Old Mar 13, 2003 | 10:24 PM
speedevo's Avatar
Default Re: which one is power and ground???! (Hybrid95CivicEX)
cool your right, also i another question now where whould i run the remote wire? there doesn't seem to be an extra 12volt slot on the accord's fuse box as opposed to a few in my teg's fusebox.
Old Mar 13, 2003 | 11:55 PM
ATF Kuk's Avatar
u can run one from ur radio. is ur radio stock?
Old Mar 14, 2003 | 12:01 AM
vteg's Avatar
New User
Default Re: which one is power and ground???! (ATF Kuk)
The radio should have the remote output if it is after market. If it is not, splice into the power wire for the head. The remote will be live whenever the car is on though.
Old Mar 14, 2003 | 02:18 AM
super laubo's Avatar
Honda/acura's are the easiest when it comes to speaker wire coloring. the brighter, livelier colors are the positive.. i.e.) red or blue. negatives are the crappy not so fun colors. i.e.) brown or gray.
you should be able to tap into ignition wire from the back of your radio if it is still stock. that year accord didn't have a power antenna so you can't tap into that if it's still the factory one. good luck!!
Old Mar 14, 2003 | 08:12 AM
speedevo's Avatar
Default Re: which one is power and ground???! (super laubo)
so i can just splice it into the power wire connecting to the back of the stock head unit? would one of you guys be able to tell me which wire i have to use? the 12 volt red or the 12 volt battery/constant yellow?
Old Mar 14, 2003 | 08:24 AM
use RED..that's ignition, unless you want your amp to be on all the time even when the car isn't turned on.
Old Mar 14, 2003 | 09:56 AM
nOOber's Avatar
I'd use accessory. why would you want your amp on when your key is in the crank postion?
Old Mar 14, 2003 | 04:07 PM
vteg's Avatar
New User
Default Re: which one is power and ground???! (nOOber)
If he splices off the power to head unit(not constant) it will not be on in crank position.
Old Mar 14, 2003 | 11:47 PM
speedevo's Avatar
well it's my friends car so wanna "measure twice cut once" idea, also i spliced into his rear speakers for the high level inputs, but we haven't hooked up the amp and he says that right now he can't get any sound in the rear, is something wrong?
Old Mar 15, 2003 | 12:57 AM
vteg's Avatar
New User
Probably bad crimp/splice. You will need a DMM if you want to do this quickly. Make sure that you are not grounding the wires that you spliced in. Use the dmm to check continuity between the added wire and the speaker terminal.
Tape the ends of the wire if they are not going to be connected right now. And do not let them ground or touch each other.
Old Mar 15, 2003 | 08:22 PM
speedevo's Avatar
okay i was gonna connect the remote lead to the back of the head unit. now there are 4 red wires, one solid red, and it didn't work until i turned the panel lights on, do you guys know which wire for the accord headunit will give power when there is power in the ignition? my other friend suggested tapping into the factory clock, is that spot okay? thanks for the help so far guys.
Old Mar 15, 2003 | 08:24 PM
bryan305's Avatar
to figure out which wire gives power in "on" position, get a voltage tester. It's a probe with a lightbulb in it that lights up when connected to a power source.
Old Mar 16, 2003 | 07:56 PM
speedevo's Avatar
Default Re: which one is power and ground???! (bryan305)
okay i used a circuit tester, on the stock radio harness now, it will not light up until i turn ont he panel lights so i won't be able to use anything there, is there anything else i can hook up the remote wire too?
Old Mar 17, 2003 | 06:10 AM
rjr162's Avatar
there's going to be a wire going into the factory radio that turns on with the key. Tha'ts what you want to look for
jayj99crv
12
Sep 18, 2018 10:07 AM
Vladglad
Aug 1, 2015 09:52 PM
MrBryan
May 28, 2007 04:27 AM
KrispyKreme
Audio / Security / Video
12
Mar 17, 2005 01:13 PM
