New turbo. Looking for injectors. Need help
Old Oct 10, 2018 | 11:20 AM
Ryan Thelion's Avatar
Default New turbo. Looking for injectors. Need help
Wassup ya'll. I just bought my first Honda in February this year. I have a 1992 Honda Accord ex coupe. Has the factory f22 sohc motor. Didn't plan on doing much with it but I got talked into getting it turbo'd. So I have the turbo hooked up and I'm looking for some injectors. Running low boost, 4-6psi since it's a stock motor. Someone recommended the dsm 450cc injectors and I've been asking around and different people are saying different stuff about a resistor box. One guy says I need either a dsm resistor box or one from a pre 91 honda and the other guy says my car already has one. Need help on exactly what I need and if these injectors are a good choice. Thanks
Old Oct 10, 2018 | 12:18 PM
TheShodan's Avatar
Moderator
Default Re: New turbo. Looking for injectors. Need help
Your 92 CB7 has the resistor pack already for the DSM injectors. But I will admit, 300whp is as good as you're going to get at over 90% duty cycle on those DSMs. If you find a set, and still must use them, you'll need to clean and flow test them first. By the time you do that, you can find some good Delphi/ Rochester-Lucas low inference injectors in 550cc for the same or less money
ceemarun
Aug 7, 2015 05:21 PM
spotscivic
Nov 23, 2007 08:20 PM
crispydee
Aug 1, 2004 02:52 AM
joeski
Apr 4, 2003 09:13 AM
